Q: vpn from c1721 to vpn3000
Kamal Malhotra Thu, 03/15/2007 - 06:46
Please explain what the problem is. Without knowing the problem noting can be suggested.
Kamal
sry..i forgot to attach log from my c1721,
problem is this vpn is does not work.and from vpn3000 side i only got 5938 03/14/2007 15:48:18.620 SEV=4 IKE/48 RPT=610 10.253.241.2
Error processing payload: Payload ID: 1
5939 03/14/2007 15:48:28.620 SEV=4 IKE/48 RPT=611 10.253.241.2
Error processing payload: Payload ID: 1.
acl is same on both sides
Kamal Malhotra Thu, 03/15/2007 - 07:04
Please issue the following commands :
interface FastEthernet0.1
no crypto map hrokVPN
exit
no crypto map hrokVPN local-address FastEthernet0.2
no crypto ipsec nat-transparency spi-matching
crypto map hrokVPN
exit
Please test it and let me know how it goes.
HTH,
*Please rate if it helps,
Kamal
