pramod.prasad Thu, 03/15/2007 - 03:21
Hi amit ,
Thanks for the link , I already through the link ,I run the command show processes cpu i got 99 % @ maximum utilization is by Cat4k Mgmt LoPr ,after trying show platform health maximum % is captured by K2L2 Address Table R by the document i came to know wht they stands for but my problem is how to resole wht to do becos if i run debug/log command then cpu usage comes to 100 % , there is no backup for this switchi.e critical switch so pls advice me to come out of this problem .
thnx
b.petronio Thu, 03/15/2007 - 03:50
Could u perform a "Show process cpu history", and show us ?
Do u have that subcommand? It depends on ur IOS version.
pramod.prasad Thu, 03/15/2007 - 04:17
thanks amit
two ports are flapping after shut down tht port cpu usage reduces to 17%.
thnx for ur support
pp
Amit Singh Thu, 03/15/2007 - 04:26
  • Cisco Employee,
Hi PP,
Glad the issue is resolved.
I would encourage you to be regular on the forum to get you issues/queries solved.
-amit singh
