purging Ciscoworks databases
Mar 15th, 2007
i have a customer that has a CW LMS 2.6 managing more than 1000 equipments.
He has enormous databases and the service level is very degraded.
Is there any thing to do with the database to purge them or to depurate them????
Thank you on advanced.
Overall Rating: 3.5 (2 ratings)
dsweeny Wed, 03/21/2007 - 08:09
Try this:
You can rotate a log files using logrot.pl , this script availableNMSROOT/bin logrot.pl
David Stanford Wed, 03/21/2007 - 09:09
  • Cisco Employee,
You won't want to use logrot.pl for databases, this is meant for the log files only. To completely clear your databases you should do the following:
dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
dbRestoreOrig.pl dsn=rmeng dmprefix=RME
dbRestoreOrig.pl dsn=ani dmprefix=ANI
dbRestoreOrig.pl dsn=cmf dmprefix=Cmf
OLOF SAMUELSSON Mon, 04/02/2007 - 05:31
More than 1000 devices can be managed with CiscoWorks as long as you have the right server hardware and are careful with the server configuration.
The big question is what is filling the databases, if you don't change that they will just get huge again, right?
