03-15-2007 03:01 AM - edited 03-09-2019 05:36 PM
I have PIX 515 and trying to add a gateway to gateway VPN tunnel with dynamic IP. I already have two other VPN tunnels configured with static IP. I enter the access-list 110 than the crypto map mymap 20 ipsec-isakmp no problem. than the crypto map mymap 20 match address 101 I get error message Crypto map incomplete. Why am I getting this error and how do I get around it. Thanks.
03-15-2007 06:06 AM
When we configure a crypto map, till the time all the parameters are not configured, we get this message. So please do a sh run and if you see any '!Incomplete' message in the crypto map then its a matter of concern else not.
HTH,
Please rate if it helps,
Kamal
03-15-2007 05:22 PM
Yes I have an Incomplete.
crypto ipsec transform-set tr-set esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set tr-set
crypto dynamic-map dynmap 15 set transform-set tr-set
crypto dynamic-map dynmap 15 set security-association lifetime seconds 3600 kilo
bytes 4608000
crypto map mymap 10 ipsec-isakmp
crypto map mymap 10 match address 101
crypto map mymap 10 set peer 70.106.123.11
crypto map mymap 10 set transform-set tr-set
crypto map mymap 15 ipsec-isakmp
crypto map mymap 15 match address 105
crypto map mymap 15 set peer 67.100.146.217
crypto map mymap 15 set transform-set tr-set
! Incomplete
crypto map mymap 6335 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
