unable to implement enable password...
Mar 15th, 2007
I have a cisco 2600 router which is in my office network...and AAA authentication enabled , it contacts AAA server and authenticate...my problem is that all my routers authenticate with aaa server..even this router...but for alone this router it is not asking enable password...when typing first username and password itself it takes to # prompt...(privillage mode). but in all other routers aaa server asking enable password...I have local username, password and enable password configured in the same router locally also..but when i tries with out AAA server the same thing happens...it is not asking enable password...after entering local usernames and password...it enters # prompt..with out..entering enable password... is this is problem with ios??
am including the reasult of the sh version command....thanks...in advance...
Cisco IOS Software, 2600 Software (C2691-SPSERVICESK9-M), Version 12.4(10a), REL
EASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 11-Oct-06 18:39 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
uptime is 9 weeks, 18 hours, 49 minutes
System restarted at 00:00:00 UTC Fri Mar 1 2002
System image file is "flash:c2691-spservicesk9-mz.124-10a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2691 (R7000) processor (revision 0.1) with 249856K/12288K bytes of memory.
Processor board ID FHK1050F1WH
R7000 CPU at 160MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
2 FastEthernet interfaces
4 Serial(sync/async) interfaces
1 ISDN Basic Rate interface
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
Richard Burts Thu, 03/15/2007 - 07:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rajesh
I believe that he was asking whether the configuration of your vty lines includes the command privilege level 15. Using the command privilege level 15 on the vty ports will take you directly to privilege mode, which is what you say is happening.
So do you have privilege level 15 configured on the vty lines?
Rick
rajesh_colt Mon, 03/19/2007 - 22:34
hi dud...
it is working , thanks...i removed privillege level 15 from vty 0 4....it is working and new...knowldge to me....thanks...great help....
