Caller ID using R1 T1 (CAS)
Mar 15th, 2007
Is there a way to pass the caller id information from a Cisco AS5850 to the TDM Switch using between them R1 T1 (CAS)?
Overall Rating: 5 (1 ratings)
pacameron Thu, 03/22/2007 - 22:35
Actually feature group D is the only T1 CAS protocol that supports caller ID. Refer to the attached note for additional detail on FGD operation and debugging -
Paolo Bevilacqua Fri, 03/23/2007 - 01:47
Correct, I sady "only" both actually both "feature group D" and "E&M feature group B" provides ANI in T1 CAS.
From the document that I've linked above:
Provides the ANI/DNIS delimiter on incoming T1/CAS trunk lines.
This feature is only functional in a T1 CAS configured for E&M-feature group b (wink start)
pacameron Mon, 03/26/2007 - 06:20
You are correct, the original message posted had mentioned he was using an AS5850 which did not register :-)
The ANI/DNIS delimter feature only works on the AS5XXX family so looks like he might be in luck.
