Load Balance outbound w/ NATs (routers two ISPs)
Mar 15th, 2007
I want to make the balancing of outbound of two ISPs. I made the following configurations, but he did not function. somebody can help me?
int s0: ISP-1
int s1: ISP-2
eth0 10.10.10.1/24
mail server 10.10.0.2
proxy/ftp server 10.10.0.3
---------------------BEGIN--------------------------------
int eth0
ip address 10.10.0.10 255.255.255.0
ip nat inside
int s0
ip adress 200.100.200.2 255.255.255.252
ip nat outside
int s1
ip address 200.100.130.2 255.255.255.252
ip nat outside
ip route 0.0.0.0 0.0.0.0 200.100.200.1
ip route 0.0.0.0 0.0.0.0 200.100.130.1
ip nat inside source static 10.10.0.3 200.20.7.130 route-map ISP-1
ip nat inside source static 10.10.0.2 200.20.7.129 route-map ISP-1
ip nat inside source static 10.10.0.3 200.13.15.25 route-map ISP-2
ip nat inside source static 10.10.0.2 200.13.15.26 route-map ISP-2
access-list 101 permit ip 10.10.0.0 0.0.0.255 any
access-list 102 permit ip 10.10.0.0 0.0.0.255 any
route-map ISP-1
match ip address 101
set ip next-hop 200.100.200.1
route-map ISP-2
match ip address 102
set ip next-hop 200.100.130.1
---------------------END--------------------------------
thanks
Cleverson Ferla
royalblues Sun, 03/18/2007 - 01:42
  • Green, 3000 points or more
Cleve,
Can you change the access-list statements to the following and check
access-list 101 permit ip 10.10.0.3 0.0.0.0 any
access-list 102 permit ip 10.10.0.3 0.0.0.0 any
HTH, rate if it does
Narayan
