SSL Services Module
Mar 15th, 2007
Hi, Can anyone please point me an example to learn how can I use the SSL Services Module in standalone mode not using any PBR in MSFC. In the configuration guide the only example is using PBR, and I dont't want to use cause im my design the traffic between the client , SSLSM and server don't pass throught the MSFC
Thanks in Advanced
Andre Lomonaco
Gilles Dufour Thu, 03/15/2007 - 08:41
  • Cisco Employee,
Andre,
PBR is there just to guarantee that the response from the server goes back to the SSLM.
If you do not use PBR, you need to find another solution to make the traffic go to the SSLM.
You can do this with static routes, but than all your traffic from the server will go through the SSLM. Even traffic that is not required to be seen by the SSLM.
Do you have a CSM maybe ?
Gilles.
