Can my 2821 handle......
zorric.sia
I recently purchased (2) 2821 routers w/ 512MB of ram.
I'm planning on running the following:
BGP w/ default routes only
Netflow
IOS IPS w/ basic signatures
Will my routers handle all of this?
Thanks in advance.
mheusinger
Level 10
Level 10
Yes.
One more parameter to take into account: what is the expected throughput? Your CPU load will depend on that (NetFlow, IPS).
Hope this helps!
Regards, Martin
Throughput is typically 6-7megs.
Should be fine.
