WCCP Support for other TCP Ports
Mar 15th, 2007
Looking for a sample config using WCCP to redirect TCP port 8080 and 8443 as well some other custom TCP ports.
Currently using the CEs/WAEs for HTTP and other standard streaming protocols.
Using ACNS 5.X. Not clear on the service group config.
ip wccp web-cache redirect-list 123
ip wccp 60 redirect-list 123
ip wccp 70 redirect-list 123
ip wccp 80 redirect-list 123
ip wccp 81 redirect-list 123
ip wccp 82 redirect-list 123
interface xxxx
ip wccp web-cache redirect out
ip wccp 60 redirect out
ip wccp 70 redirect out
ip wccp 80 redirect out
ip wccp 81 redirect out
ip wccp 82 redirect out
alejrodr Thu, 03/15/2007 - 08:55
Please take a look at this doc, will help you with the redirection of 8080 and 8443.
For the other services, it is pretty much as you have them on the router.
You will need to enable them on the CE as well.
Something like this for WMT and RTSP:
ip wccp web-cache
ip wccp 80
ip wccp 81
ip wccp 82
ip wccp 83
interface FastEthernet0/1
description to WAN
ip address xxxxxxx
ip wccp 83 redirect out
wccp router-list 1
wccp web-cache router-list-num 1
wccp rtsp router-list-num 1
wccp wmt router-list-num 1
wccp version 2
Hope it helps.
jtorjman Thu, 03/15/2007 - 09:37
Are the actual TCP Ports (non standard) configured on the CDM GUI? The CE then tells the wccp router to look for that TCP port based on the service number.
(We have some web apps on TCP 2000 and 3000.)
