RTP encryption
chris.damore
I have configured IP phone encryption phone-to-phone. Now I would like to configure encryption phone to h323 gateways so incoming and outgoing calls are encrypted to/from the gateways. Does anyone have a link or any information about this?
Chris
Chris, I didnt mean to say that.
H323 encryption is supported in 4.1,4.2, 5.x etc. You have to have a min. IOS version to support SRTP command under dial-peers.
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a008068b526.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
9 Replies 9
thisisshanky
Level 11
Level 11
Yes, its very simple. Enable encryption under the dial peers, using command
"srtp".
If using a MGCP gateway, you have to configure a few commands for MGCP to enable signalling encryption. To setup media encryption for RTP you will have to build a ipsec tunnel to callmanager (pub and sub's).
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a008068b526.html#wp1123262
HTh
Sankar
PS: please remember to rate posts!
Sankar Nair
Do you know how RTP encryption works with IPCC?
Chris
Chris,
CM 4.1 doesnt support encryption on CTI devices. It seems CM 5.x has support for encryption on CTI devices, but i have never setup encryption to IPCC.
Sankar Nair
So this would mean any RTP traffic from IPCC wouldn't be encrypted?
Also, do you know if this is the case in CM 4.2?
Chris
Looks like its not supported in 4.2 as well.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_2/sec_vir/ae/sec423/secuview.htm
Hopefully this is roadmapped for 4.x train in future.
Sankar Nair
So the H323 encryption is only supported in CM5.0 and above?????
Chris
Sankar Nair
Jason Aarons
Level 6
Level 6
I would discourage srtp/encryption, too many things won't work or have caveats. Give it some time to work out the issues.
Can you tell me some of the things that don't work or have caveats?
Chris
