how to page to fxs port and all ip hones at the same time
Mar 15th, 2007
I have read a lot of information regarding setting up an overhead paging system with an fxs port using ccme. So I have it all setup and working. I can dial the extension fine, and page through the overhead system fine, but how do I configure the router so when I page to all ip phones, it also goes to the fxs port? I know I can use an ata 188 or 186, but can I use a standard fxs port on a voice card? Thanks for your help
paolo bevilacqua Thu, 03/15/2007 - 14:06
  • Hall of Fame,
    Founding Member
I assume you are using CCME.
If so, you can try the "SCCP client" feature, so that FXS ports are handled like ephones:
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a0080483a76.html
I have't tried that myself, but it's worth a try.
Basically, the SCCP client will register using a loopback or local interface to the same router, then you can try to enable to paging features.
Hope this helps, if so please rate post!
brooks.dustin Fri, 03/16/2007 - 08:53
I would also like to find out another solution other than ata's. How are you paging to all the ip phones?
paolo bevilacqua Fri, 03/16/2007 - 14:20
  • Hall of Fame,
    Founding Member
Other that ATA, read my reply above. You would be using the paging support that is embedded in CCME. Of course the analog phone or pagins system must be supporting auto-answer.
EZEQUIEL FERREIRA Wed, 07/21/2010 - 14:31
Did you find the answer?  I also a customer that wants to both, and we have a Bogen TAM-B answering the analog phone, but we can only page one at a time.  Both does not seem to work.
Zeke
