How to configure AIM-ATM in 2811?
Mar 15th, 2007
I have a 2M ATM circuit on RJ45. Is there any special requirement for a 2811 with AIM-ATM module to use the ATM circuit? Any sample config?
virenderj Thu, 03/15/2007 - 10:54
Lets say you have AIM card in slot 1 and VWIC card installed in WIC2 slot
network-clock-participate wic 2
network-clock-participate aim 1
network-clock-select 1 E1 0/2/0
controller E1 0/2/0
mode atm aim 1
interface ATM0/IMA3
no ip address
no atm ilmi-keepalive
interface ATM0/IMA3.77 point-to-point
pvc 1/77
ubr 3840
oam-pvc manage 0
encapsulation aal5snap
interface ATM0/2/0
no ip address
no scrambling-payload
ima-group 3
Hope this helps.
sahernizamlimat Thu, 03/15/2007 - 20:50
Unfortunately I do not have any VWIC card installed. Can I used the FastEther since the 2M ATM that the ISP provide is on RJ45?
virenderj Thu, 03/15/2007 - 20:58
Unfortunately you cannot get away by terminating at FastE, I know ISP provides RJ45 but that must be getting terminated on VWIC on 2811. RJ45 do not understand ATM format hence you would need a vwic at a minimum in order to turn up the ckt.
