Cant get switch to see BPDU'S via asa firewall
Mar 15th, 2007
Hi all, can someone help. I have a setup, using a asa in transparent mode, switch A goes into inside of asa, then switch 2 plugs into outside of ASA, I have created an allow all rule, BUT i cant see the bpdu's coming through to the other switch, can anyone please help?
cheers
Carl
Amit Singh Thu, 03/15/2007 - 10:17
Carl,
Configure the following on your ASA:
hostname(config)# access-list ETHER ethertype permit bpdu
hostname(config)# access-group ETHER in interface inside
hostname(config)# access-group ETHER in interface outside
HTH,Please rate if it does.
-amit singh
adimakmur Mon, 09/17/2007 - 19:25
Hi Carl,
Can you share your experience how you solve the bpdu issue on the ASA?
Right now, I'm having the same problem. I have tried using the Ethertype access-list to allow the bpdu, but still cannot. The hit-count on the access-list is not increased.
Thanks a lot for your help.
-Adi-
