is vlan.dat file still important on routers?
Answered Question
Mar 15th, 2007
We have a Cisco 2821 router that will have an IOS upgrade via a new flash chip. If my startup-config contains all the useful information (on NVRAM) about the interfaces, do I really need to keep the vlan.dat file? My guess is that it a holdover from the early VLAN configuration process, and as long as I have a switch acting as a VTP server, I can discard the vlan.dat in the router's flash. Yes?
Correct Answer by ankbhasi about 10 years 1 month ago
Hi Jim,
Is your router is having switch module? Was is also working as a VTP server?
If you already have a VTP server in your network up and running you can delete vlan.dat file and it will get updated on this router once you put it back into the network.
Ankur
Overall Rating: 4 (2 ratings)
Correct Answer
ankbhasi Thu, 03/15/2007 - 10:21
  • Cisco Employee,
Hi Jim,
Ankur
jimmyc_2 Thu, 03/15/2007 - 10:34
Ankur,
Exactly as I suspected, thanks for very prompt response.
I should use this forum more often.
Jimmyc
jimmyc_2 Thu, 03/22/2007 - 06:13
Hi Ankur,
Perhaps I should have mentioned that we have VLAN interfaces configured on our router. Even though we don't have a switch module on the router, the vlan.dat file is definatley needed to bring up the "vlan 101 interface". After the reload, all of our virtual VLAN interfaces came back as "up/down" until we reloaded the vlan.dat
jimmyc
Amit Singh Thu, 03/15/2007 - 10:33
  • Cisco Employee,
Jim,
If you using Etherswitch module and its L2 features with vlan enabled on it, do not delete vlan.dat file. If you are not using router for the L2 switch features, then its safe to remove the vlan.dat file.
HTH,
-amit singh
