CIsco Secure Desktop in VPN 3000
Mar 15th, 2007
i am trying to configure Secure Desktop in my Concentrator VPN 3000 to access by WebVPN. Now i have a configuration very simple of CSD to test how it works, but when finish the installation doesn`t switch to SecureDesktop, nothing occurs!! Display this: "Secure Desktop is unloaded". When i click "switch SecureDesktop" try to load it but fails.
Does anybody know what is going on?
I attach my xml config file for Cisco Secure Desktop.
Thanks in advance and best regards,
mfreijser Thu, 04/12/2007 - 00:29
  • Bronze, 100 points or more
I had this problem with some workstations. The solution was in almost all cases the following: Remove the CSD from the workstation through the "Add and Remove Programs" Control Panel applet, and retry connecting to the Concentrator.
Sometimes the installation of the CSD fails, resulting in strange behaviour ;)
Hope this posts helps, if ti does; please rate!
Michael
