hoogen_82 Fri, 03/16/2007 - 01:13
Are you doing an authentication using a local database or windows ad server?
Hoogen
hoogen_82 Fri, 03/16/2007 - 08:49
I have done this before but dont have an ACS in my hand to tell you exactly what you need to do.
Try these links http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_user_guide_chapter09186a008052e965.html#wp222215
If i am right either in the above field or in the user attributes you can click on field where it says reset password on login. And then set the password aging fields
Hoogen
