11503 and port monitoring
jjoseph01
Level 3
Level 3
Does anyone know if you can do port monitoring (I want to use a sniffer on a particular port) on an 11503? If so, anyone know the command? Thanks.
If you are 7.2 and higher code then your answer is below
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a008015834c.html#wp1099686
Hope it helps
Syed Iftekhar Ahmed
alejrodr
Can you monitor more than one port to one destination port? Like ports 1, 2 and 3 to port number 4?
A SPAN session is the association of a destination port with a source port on the same CSS module. The port that is monitored is called the source SPAN (SSPAN) port.
SPAN can monitor the ingress path, the egress path, or both. You can configure only one SSPAN port in a CSS chassis.
