1801w ISR and mapping VLAN, WLAN and VRF
Mar 15th, 2007
I have a problem with getting SSID and local vlans to work unless I create subinterfaces on radio interface. If the VLAN is then associated to a VRF and VRF DHCP pool I won?t get an IP over WLAN.
Has anyone experience with such a solution with the intergrated radio?
Using LWAPP Hybrid REAP AP?s on a trunk (fa8) interface works just fine...
drolemc Thu, 03/22/2007 - 06:38
  • Silver, 250 points or more
Try the command ip dhcp use vrf connected in order to assign the ip address through DHCP.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
