Configuring RIP
admin_2
Level 3
Level 3
In preparation for my CCNA exam I found a test question that is a bit confusing. The config is as follows:
Note: the routing protocol is rip
(config) int e0
(config-if)ip address 192.168.81.33 255.255.255.224
config-if)no shutdown
(config) int s1
config-if)ip address 192.168.81.65 255.255.255.224
The question never shows the network statements.
Since rip is a classfull routing protocol I would think that the 255.255.255.224 subnet mask is pointless.
I will not advertise that subnet right?
So since it wont advertise that subnet the subnet mask on both interfaces should be 255.255.255.0
If the routing protocol was eigrp,ospf, or ripv2 you would be okay with the
255.255.255.224 subnet mask. The above routing protocols support vlsm.
Am I on the right track or am I missing somthing?
Thank you in advance.
8 Replies 8
You are partly correct. RIP v1 doesn't net send subnet mask info in it's updates. RIP v1 doesn't support VLSM. But, it does support fixed length subnet mask.
Take a look at this example. In the below scenario, both R1 & R2 run RIP v1 on all the interfaces. Since R1's ethernet and s0 are configured with the same subnet mask it would send a routing update for 192.168.1.0. R2 knowing the subnet mask is 255.255.255.224 on it's s0 interface it would apply the same subnet mask for the 192.168.1.0 it learnt from R1.
R1:
int e0
ip add 192.168.1.1 255.255.255.224
int s0
ip add 192.168.2.1 255.255.255.224
R2:
int s0
ip add 192.168.2.2 255.255.255.224
Sundar
Not applicable
So in this example, just maintain the same subnet mask on your interfaces and you would be okay?
Your adverised routes would still be classfull but you would still communicate with no problems between r1:ints0 and r2:ints0.....they are on the same subnet.
Makes sense now that you explained it.
Thank you for your help!
Don
Yes, your understanding is correct:)
Not applicable
