CISCO MGCP
Mar 15th, 2007
Guys, I have configured a cisco 2821 for mgcp and my console port keeps on displaying the following message.
*Mar 16 01:29:18.887: [S] mgcp_msg_ack:6075,Updating (*)=172.232.31.81
*Mar 16 01:29:48.887: [S] mgcp_msg_ack:6075,Updating (*)=172.232.31.80
mutiple times. Any ideas on what would be causing this?
Overall Rating: 5 (1 ratings)
Erick Bergquist Sun, 03/18/2007 - 00:48
  • Silver, 250 points or more
What IOS version?
This is a cosmetic bug, you'll see it when ccm-manager does a config push.
Bug id CSCsh76950
Symptom:
An ISR router using the ccm-manager feature to configure the voice ports in the router will
see a group of cosmetic errors in the log during the configuration.
Conditions:
This issue is seen in ISR routers which are configure by the Cisco Callmanager using the
ccm-manager feature. The CCM will upload the configuration to the router for all the voice
ports. This configuration will generate some errors.
Workaround:
This problem is cosmetic only, so no adverse condition will be seen if feature is used. If the customer
doesn't want to see any errors in the logs, then the ccm-manager feature can be disable and configuration can be done manually.
Please rate helpful posts.
hala samy Mon, 12/24/2012 - 01:07
i just have this message on my 2811 router
C2800NM-ADVIPSERVICESK9-M), Version 12.4(23)
i just removed the mgcp configuration from the router and put it back again
no mgcp and then put back the configuration
it works for me
and if this msg appeared back again try to reboot your router
paolo bevilacqua Mon, 12/24/2012 - 13:34
  • Hall of Fame,
    Founding Member
Reboot router to not produce an harmless message ?!?
hala samy Tue, 12/25/2012 - 00:26
first remove the mgcp configuration
and if it didn't work out for you restart your router
it worked for me just with removing the configuration and applying it back again
but in my search their 's people who solved it with restarting their router
