CME 4.0 - Cannot create monitor extensions on a 7914 expansion module
Mar 15th, 2007
I'm having a problem with a 7914 expansion module attached to a 7960. There are 2 of these 7960's on the CME router, and my client wants both of these phones to have identical monitor extensions. I configured the first phone without any problems, but the 2nd phone is giving me fits! Every time I create a "monitor" extension in the GUI or the CLI, it ALWAYS defaults to "Normal Ring" instead of "monitor".
Is this happening because you cannot have two phones monitoring the same extension in CME 4.0?
paolo bevilacqua Fri, 03/16/2007 - 14:32
  • Hall of Fame,
    Founding Member
I'm not aware of such a limitation. You may want to share some more config detail here, including FW for the phones, etc.
todd.carswell Fri, 03/16/2007 - 14:36
I found the issue: It's a bug with the CME GUI files. The workaround is to configure the monitor extensions manually and update the GUI files with the compatible version.
paolo bevilacqua Fri, 03/16/2007 - 14:39
  • Hall of Fame,
    Founding Member
Very good. In fact you can find that is better to do most of the configuration manually not only because the too many limitation of the current GUI, but also because CLI is more powerful and direct.
