CatOS to Native IOS
ankbhasi Fri, 03/16/2007 - 01:10
  • Cisco Employee,
Hi Neo,
Once you are done with the conversion of code and config from CATOS to NATIVE IOS you are good to go.
If you have 2 sups in your chassis then you can plan for redundancy between your sups using rpr or rpr+ or sso if you have sup 720.
Ankur
*Pls rate helpfull post
