1100 AP
Mar 16th, 2007
i'm having issues with my AP. It was mistakenly changed to DHCP from static, and unfortunately, there is no DHCP server running. I dont know how to access the GUI so as to statically configure the IP address. The setback i have is, the AP doesnt have a console port, so i have to figure out a way to fix it. Please help.
jeromehenry_2 Fri, 03/16/2007 - 01:58
  • Silver, 250 points or more
If DHCP is not found, AP reverts to defaul behaviour, which is to set its IP address to 10.0.0.1/24. You have a 5 mn window to access it... just set your IP to any address in that range (or let the Ap internal dhcp provide you with one), and connect to it...
You can also reset the AP (with Mode switch , waiting red light), and then connect to http://10.0.0.1 using password Cisco...
hth
J
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
