pdm and ca authentication fingerprint
adriatikb
Hi all
I cant access From PDM my pix515 device.
When I put ca enroll with all requested options , is going to tell -
% No CA root cert exists. Use "ca authenticate"
but that step i done successfully
can you help me ?
what is optional fingerprint ? is it really optional?
thank you
carenas123
Level 5
Level 5
This document demonstrates how to configure an IPSec VPN tunnel between a PIX Firewall and a Cisco VPN Client 4.0.x. The configuration example in this document also highlights the certification authority (CA) enrollment procedure for both the Cisco IOS? router and the Cisco VPN Client, as well as the use of a Smartcard as a certificate storage.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094e69.shtml
hello,
thank you for this document !
maybe i cant explain first of all i need to connect with pix tough PDM , which is going to tell me that certificate i incorrect.
what can i do for that?
the pix is as....
Cisco PIX Firewall Version 6.3(4)
Cisco PIX Device Manager Version 3.0(2)
Compiled on Fri 02-Jul-04 00:07 by morlee
pix515ekesh up 3 days 23 hours
Hardware: PIX-515E, 32 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 000f.243f.5103, irq 10
1: ethernet1: address is 000f.243f.5104, irq 11
2: ethernet2: address is 0002.b3ec.3707, irq 11
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 3
Maximum Interfaces: 5
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
