Switch Boot Time
Mar 16th, 2007
I have a group using two switches. A WS-3560G-48TS and a WS-3750-24TS. I am trying to find some documentation that suggests a normal boot/load time for those switches. The 3560 is taking about 3.25 minutes and the user is not happy with that. Does anyone know where this is documented? Or have recommendations on speeding it up? Thanks
Overall Rating: 3 (1 ratings)
ahmednaas Fri, 03/16/2007 - 06:34
I don't think you can do any thing about the time it takes the switch to finish the boot process. All Cisco devices take a seemingly long time to boot.
And why is the user concerned about the boot time of the switch? How many times a day/week/month do you reload it? And during working hours?
jasommer Fri, 03/16/2007 - 06:46
A little more background:
These switches are used in a training system. In the morning they hit one power switch and everything comes on. Most of the PCs are diskless booting and tend to come up faster than the switches. They usually timeout (Boot P times out), and have to be reset once the switches are up. Apparently it is just the WS-3560G-48TS that is causing the problem. It is running 122-25.SEB4.
ahmednaas Fri, 03/16/2007 - 06:51
In this case you can configure "spanning-tree portfast" on ports connected to pc'. This will cut the time by about a minute from the perspective of pc users.
glen.grant Fri, 03/16/2007 - 07:14
there is no way around this . Find a live plug and leave the switch on which is what most users do .
jasommer Fri, 03/16/2007 - 06:54
More information: The 3.25 minutes is the time it takes for the switches to start passing any traffic. Portfast is enabled on all the server/pc interfaces. Thanks.
ahmednaas Fri, 03/16/2007 - 07:02
Unless you are loading new/default condigurations every morning, you could consider leaving the switch on over-night. Not great for your carbon footprint, but it might keep the users happy.
Amit Singh Fri, 03/16/2007 - 07:58
You cannot do much about making the booting process faster for the switch. It has to load the IOS, run the hardware test and then load the IOS and config on the DRAM. Moreover on 3750 it runs the stack election process that's why 3750 usually takes long time.
As suggested by Glen and Ahmed, we cannot do much about it and just leave the switch running overnight.
-amit singh
jasommer Fri, 03/16/2007 - 08:21
Thank you all, but I guess my real question is this: Is 3.25 minutes "normal" for the 3560? Is a "normal" time documented any where that I can use as a reference? Thanks a lot.
