the bug CSCsd94055
Answered Question
Mar 16th, 2007
In the bug CSCsd94055 are the wrong Fixed-in versions of IOS. Do you know which are correct Fixed-in versions?
Thank you.
Roman
Correct Answer by suschoud about 9 years 11 months ago
you can open up a case with tac so that they could provide the files.
thx
sushil
cisco tac
Overall Rating: 5 (1 ratings)
suschoud Fri, 03/16/2007 - 08:24
12.4(12.4), 12.4(12.3)T are the first fixed versions.
sushil
cisco tac
ROMAN TOMASEK Fri, 03/16/2007 - 08:35
These versions are not possible to download from CCO. Is it possible to get these versions or is some date when the IOS from these versions will be on CCO?
Thank you
Correct Answer
suschoud Fri, 03/16/2007 - 08:40
thx
sushil
cisco tac
