find ip of host from router
Mar 16th, 2007
If a router is connected to a network with several pc hosts and the ip of these hosts are not configured with a hostname on the router, furthermore, the mac address of these hosts are unknown, is there a way to find the ip add of a certain pc from the router console granting that this particular pc is a server (e.g. accounting server )?
I would be grateful for any info on this.
Amit Singh Fri, 03/16/2007 - 09:10
The only way to know this is by checking the PC' s MAC address and then checking the ARP table on the router by using "show arp". To check the PC's mac address go to START--> RUN--> CMD-->ipconfig/all.
You can also use a freeware tool " CCgetmacaddress", this tool will give you IP by MAC or MAC by IP.
-amit singh
marcusbrutus Sat, 03/17/2007 - 02:19
Is there no way to find the ip add of a server from the router without going physically to the server?
Note: The mac add of the server is unknown and no hostnames existing in the router.
Jon Marshall Sat, 03/17/2007 - 02:34
Unfortunately no. The router has an arp table which maps IP addresses to mac-addresses. If you knew one you could get the other but as you don't know either it is impossible to tell.
What is it you are trying to do exactly ?
