Warning message
BGP peer timing out
Mar 16th, 2007
Good day;
I'm trying to set up a BGP connection but the peers never connect. When I do a sh BGP neighbor I see No active TCP connection. I also ran a debug and get the following:
Mar 16 16:35:02.512 UTC: BGP: 10.128.72.154 open active, local address 10.128.72.156
Mar 16 16:35:02.512 UTC: TCB6769CF90 created
Mar 16 16:35:02.512 UTC: TCB6769CF90 setting property TCP_WINDOW_SIZE (0) C0480020
Mar 16 16:35:02.512 UTC: TCB6769CF90 setting property TCP_MD5KEY (5) 0
Mar 16 16:35:02.512 UTC: TCB6769CF90 setting property TCP_TOS (11) C0480000
Mar 16 16:35:02.512 UTC: TCB6769CF90 setting property TCP_OUT_TTL (24) 6769CAA6
Mar 16 16:35:02.512 UTC: TCP: Random local port generated 21102
Mar 16 16:35:02.512 UTC: TCB6769CF90 bound to 10.128.72.156.21102
Mar 16 16:35:02.512 UTC: TCP: sending SYN, seq 19990871, ack 0
Mar 16 16:35:02.512 UTC: TCP0: Connection to 10.128.72.154:179, advertising MSS 1460
Mar 16 16:35:02.512 UTC: TCP0: state was CLOSED -> SYNSENT [21102 -> 10.128.72.154(179)]
Mar 16 16:35:04.512 UTC: 10.128.72.156:21102 <---> 10.128.72.154:179 congestion window changes
Mar 16 16:35:04.512 UTC: cwnd from 1460 to 1460, ssthresh from 65535 to 2920
Mar 16 16:35:04.512 UTC: TCP0: timeout #1 - timeout is 4000 ms, seq 19990871
Mar 16 16:35:04.512 UTC: TCP: (21102) -> 10.128.72.154(179)
Mar 16 16:35:08.512 UTC: TCP0: timeout #2 - timeout is 8000 ms, seq 19990871
Mar 16 16:35:08.512 UTC: TCP: (21102) -> 10.128.72.154(179)
Mar 16 16:35:12.831 UTC: TCP0: state was SYNSENT -> CLOSED [49992 -> 10.128.72.155(179)]
Mar 16 16:35:12.831 UTC: TCB 0x7089878C destroyed
Mar 16 16:35:12.831 UTC: BGP: 10.128.72.155 open failed: Connection timed out; remote host not responding, open active delayed 27492ms (35000ms max, 28% jitter)
Mar 16 16:35:16.511 UTC: TCP0: timeout #3 - timeout is 16000 ms, seq 19990871
Mar 16 16:35:16.511 UTC: TCP: (21102) -> 10.128.72.154(179)
Mar 16 16:35:32.510 UTC: TCP0: state was SYNSENT -> CLOSED [21102 -> 10.128.72.154(179)]
Mar 16 16:35:32.510 UTC: TCB 0x6769CF90 destroyed
Mar 16 16:35:32.510 UTC: BGP: 10.128.72.154 open failed: Connection timed out; remote host not responding, open active delayed 29168ms (35000ms max, 28% jitter)
Any ides? I've been looking at this for a day now need fresh eyes to point out what I'm missing. Thank you in advance
Richard Burts Fri, 03/16/2007 - 09:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Warren
The debug shows that this router is running BGP and is attempting to open a connection to a neighbor (which is what you described - the debug confirms it). I do not see anything here that indicates that there is a problem on this router. What the debug shows is that this router is not receiving any response from the other router. I suspect that the issue is on the other router. I suggest that you check the configuration of the other router. It is especially important to verify that the other router is configured for BGP, that it has a neighbor statement for this router, and that the router does not have any access list filtering which would not permit the BGP packets.
Check these things and let us know what you find.
Rick
wgranada1 Fri, 03/16/2007 - 10:01
Thank you Rick the other router belongs to
a vendor I will have him check is setting again...not that it makes any difference but this is connecting to a Juniper router...will let you know what happens and thanks again!!!
Richard Burts Fri, 03/16/2007 - 10:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Warren
I think it does not matter which vendor router you are connecting to. You are sending the TCP SYN packet in initiate a connection and it looks like they are not responding. So the question is why are they not responding. The mechanics of how you configure it and how you check it are different by vendor but the question of why they do not respond is fairly universal.
Rick
wgranada1 Fri, 03/16/2007 - 11:12
no your right Rick BGP or whatever routing protocol is the same just the way you check it may be done differently...that was more of a FYI then anything but thank you for the info!!!!
