Host using NAT for incomming anf PAT for outgoing
Mar 16th, 2007
I am trying to setup a host that accepts incomming traffic via its nat'd address, but when contacting other hosts on the internet uses the outgoing iterface ip address.
I have the incomming NAT working but with the access rule etc, but I can not figure out how to have it not use the the incomming nat address for the outgoing traffic also.
I have an asa-5510.
vitripat Fri, 03/16/2007 - 10:54
It is possible. Assuming that the internal server is a TELNET server, you can have following commands in with:
public-ip(for incoming traffic)
private-ip(internal server ip)
static (inside,outside) tcp public-ip 23 private-ip 23
nat (inside) 1 0 0
global (outside) 1 interface
clear xlate
With above commands in, assuming you have correct ACLs in place, all inbound TELNET traffic to public-ip will be directed to private-ip, however, when server itself needs to initiate outbound connection, it will use the IP address on the outside interface IP.
Hope that helps.
