inter-vlan routing question
Mar 16th, 2007
how do i choose/filter which vlans can route to other vlans? i have a 3750 with four subnets/vlans attached (two access, two management). i want to prevent mgmt vlan traffic from being routed into the access vlans and vice versa. i do obviously want to keep mgmt-to-mgmt and access-to-access vlan routing. do i use private vlans for this?
acomiskey Fri, 03/16/2007 - 12:47
One solution would be to write an acl. If vlan 100 were an access vlan
access-list 100 deny ip any
access-list 100 permit ip any any
int vlan 100
ip access-group 100 in
sundar.palaniappan Fri, 03/16/2007 - 13:24
You can use VACLs to block data traveling between VLANs. If you aren't already familiar with VACLs use this configuration example..
int vlan 1
description Management VLAN
ip address
int vlan 2
description user VLAN
vlan access-map TEST 10
match ip address Management
action drop
vlan access-map TEST 20
action forward
vlan filter MANAGEMENT vlan-list 2
ip access-list extended Management
permit ip any
In this example, the switch would drop all traffic originated from VLAN2 destined to VLAN1(management vlan).
