Bridging Autonomous AP 1200 to LWAPP 1200 with WiSM
Mar 16th, 2007
We have a Wism with a number of converted AP1200's on it. I have a dedicated SSID for the bridge connection. I have a AP1200 in Autonomous mode that I want to use as a WGB to bridge a machine to the LWAPP network. It was working fine when it was 2 Autonomous AP's now we coneverted the one that was attached to the wired net and the connection is not working right.
Is this even possible.
Overall Rating: 4.5 (2 ratings)
Rob Huffman Fri, 03/16/2007 - 13:21
Hi Jeffrey,
Unfortunately, this is not supported. Have a look;
Q. Do LWAPP APs support WGB?
A. WGB functionality is only implemented on autonomous IOS APs, not on LWAPP APs.
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps441/products_qanda_item09186a0080094644.shtml#q22
The following Cisco Aironet access points have the ability to operate as autonomous access points or lightweight access points:
Cisco Aironet 1240 AG Series Access Points
Cisco Aironet 1230 AG Series Access Points
Cisco Aironet 1200 Series Access Points that contain 802.11g (AIR-MP21G-x-K9) and/or second-generation 802.11a radios (AIR-RM21A-x-K9 or AIR-RM22A-x-K9)
Cisco Aironet 1130 AG Series Access Points
Cisco Aironet 1100 Series Access Points that contain 802.11g radios (AIR-AP1121G-x-K9)
Cisco Aironet 1300 Series Access Points/Bridges (AIR-BR1310G-x-K9 or AIR-BR1310G-x-K9-R). A Cisco Aironet 1300 Series operating in LWAPP mode only operates as an access point. This series does not support LWAPP bridging mode.
The LWAPP-capable access points listed above can be ordered configured for lightweight operation, or can be upgraded from autonomous access point mode to lightweight mode using the Autonomous to Lightweight Mode upgrade tool. Orderable access points configured for lightweight operation contain an "LAP" prefix in the part number, such as AIR-LAP1310G-x-K9. Orderable access points configured for autonomous operation contain the standard "AP" prefix, such as AIR-AP1242AG-x-K9, or "BR" in the case of AIR-BR1310G-x-K9.
From this good doc;
http://www.cisco.com/en/US/products/ps6108/prod_bulletin0900aecd80321a2c.html
Hope this helps! Sorry about that
Rob
jeffreyhammond Fri, 03/16/2007 - 13:30
I dont want to use a LWAPP AP for a WGB... I want to use an IOS ap in WGB mode to connect to a LWAPP ap as a client.
Rob Huffman Fri, 03/16/2007 - 18:52
Hi Jeffrey,
I'm sorry I didn't really explain that very well :( The IOS AP is unable to connect to a LWAPP AP in WGB mode. You will need to use two IOS AP's for this function.
Hope this helps!
Rob
Guillaume BARBEROT Wed, 10/10/2007 - 09:22
not working for me ...
IOS AP : 1121 with IO 12.3.8.JEB1 (fat)
LwAPP : WLC 4402 v 4.1.185.0 with LAP 1240
not association
loysona Tue, 11/13/2007 - 07:16
working for me !
IOS AP: 1131 with IOS 12.4(3g)JA1
LWAPP: WLC4404-100 v4.1.185.0 with LAP 1131 and 1242
Now trying to get it work using EAP-FAST.
Anyone tried that already ?
Guillaume BARBEROT Tue, 11/13/2007 - 07:59
Hello all
Here are the configuration i got working:
WLC : 4.1.185
AP : 1242AG, IOS 12.4(10b)JA
WPA-PSK-TKIP
Bye
Trending Topics - Security & Network
