AIP-SSM configuration assistance
Answered Question
Mar 16th, 2007
I have two questions regarding the AIP-SSM.
1) Does the ACL on AIP-SSM have any type of relations to the ASA ACL?
2) Our four interfaces are all in use. Is it possible to assign the SSM an IP address in the same subnet as the management interface?
3) Should then the management interface be used as the gateway for the SSM?
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 65.x.x.1 255.255.255.0 standby 65.x.x.2
interface GigabitEthernet0/1
nameif dmz
security-level 50
ip address 172.16.x.1 255.255.255.0 standby 172.16.x.2
interface GigabitEthernet0/2
nameif inside
security-level 100
ip address 192.168.x.1 255.255.255.0 standby 192.168.x.2
interface GigabitEthernet0/3
description LAN/STATE Failover Interface
interface Management0/0
speed 100
duplex full
nameif management
security-level 100
ip address 10.0.x.1 255.255.255.0 standby 10.0.x.2
management-only
Correct Answer by vitripat about 9 years 10 months ago
Here are the answers to your questions-
Ans) No. ACL on SSM is completely independent of ACLs on ASA.
Ans) Absolutely. You can assign the management port of SSM an IP in the same subnet as your managemnet interface. That way all management traffic will be kept independent of normal DATA traffic.
Ans) You are right .. :-)
Hope that helps.
Vibhor.
Overall Rating: 4.5 (2 ratings)
Correct Answer
vitripat Fri, 03/16/2007 - 13:10
Hope that helps.
Vibhor.
Tshi M Fri, 03/30/2007 - 06:32
after making changes to the IDS sensor, it prompts for a node reboot. does this reboot affect the firewall as well (i.e. causing the firewall to reboot)?
marcabal Fri, 03/30/2007 - 09:45
The reboot required is just for the IPS on the SSM. The ASA itself will not be rebooted, it is only the SSM module that will be rebooted.
vitripat Fri, 03/30/2007 - 10:05
If your ASA configuration is using the SSM module and it is configured as "fail-close", then only you will face issues when SSM module is reloaded. Make sure that ASA is configuration has following line if using SSM services-
ips {inline | promiscuous} fail-open
This way even if you reload the SSM module it wont break the traffic through ASA.
Hope that helps.
Vibhor.
jshelmer Fri, 03/30/2007 - 11:49
Not only that, but if your ASA's are in a failover configuration, if you reboot the SSM on the primary firewall, it will cause a failover to the standby.
