EoMPLS vs SDH
Mar 16th, 2007
I have a requirement for a 1gb circuit between our 2 datacentres. I have been getting quotes from service providers and now have a short list of 2.
1 is offering an Ethernet over SDH circuit and the other is offering an Ethernet over MPLS circuit.(EoMPLS)
With all other things being equal, i.e. cost, SLA's etc, could I have opinions on which one you would go for and why ?
Note we will mainly be using the link for backing up approx 3-4 terabytes of data overnight, so we will be using the full 1gb.
Lee
thomas.chen Thu, 03/22/2007 - 12:09
The advantages of EoS are its abilities to leverage on existing infrastructure, superior protection and fault isolation whereas EoMPLS supports fast reroute capability and has limited restoration options. You should be able to use 1 gb in both the cases, however I will prefer EoMPLS.
s.tanner Fri, 03/23/2007 - 12:23
You will probably get bigger MTU (data per packet) with EoMPLS and hence better throughput. Assuming that RTT (round-tip time) and packet loss are equal.
