PIX501 VPN SETUP IS NOT Passing Traffic
Mar 16th, 2007
I've setup a pix501 for remote access vpn using the cisco client and found some documentation on the setup and have done this before with no problems. I pasted my modified config into the pix with no problems and connected to it fine. it just doesnt want to pass any traffic. I thought it was a nat 0 issue and i cant prove it either way! Any help is appreciated attached is my complete configuration.
acomiskey Fri, 03/16/2007 - 13:42
  • Green, 3000 points or more
try adding
isakmp nat-traversal
Patrick.Beaven Mon, 03/19/2007 - 06:16
You were Right-On! Thanks,
I totally forgot that command.
Pat
acomiskey Mon, 03/19/2007 - 06:23
Good to hear.
please rate if it helped
