CUE-AIM specs question
Mar 16th, 2007
  • Silver, 250 points or more
I need to know if I have the CUE-AIM with 1GB or 512MB is there a way to figure this out through the command line?
I appreciate quick feedback,
Regard,
Overall Rating: 4 (1 ratings)
thisisshanky Fri, 03/16/2007 - 14:16
  • Purple, 4500 points or more
Check this link.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_field_notice09186a00803e1911.shtml
In the gui, go to Help - > Aboutand if the max message space is 480 mins you have a 512 mb flash. If its 840 mins you have a 1 gig flash.
You can RMA this module to get one with 1 gig flash if you have a service contract.
Sankar
PS: please remember to rate posts
