paolo bevilacqua Fri, 03/16/2007 - 14:26
  • Hall of Fame,
    Founding Member
Yes it does, NM-1T3/E3. The next bigger router is the 7200.
Hope this helps, if so please rate post!
sundar.palaniappan Fri, 03/16/2007 - 14:27
  • Green, 3000 points or more
3800 Series routers sure does support DS3 cards. Look under table 3 in the link below.
http://cisco.com/en/US/products/ps5855/products_quick_start09186a00802d11be.html
Use Cisco Feature Navigator tool on CCO and select the 'search by platform' option and to configure the hardware. Here's the link..
Sundar
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
abbas.ali Fri, 03/16/2007 - 15:29
Eventhough 3824 supports T3, but what does it refer to in a model comparison chart that 3824 only supports 1/2 T3 (Services at Line Rate) while 3845 supports T3 (Services at line rate.
