abinjola Fri, 03/16/2007 - 16:53
  • Cisco Employee,
The page just takes ages to load right ?
well you need to upgrade to the latest pdm image pdm-304.bin
See if this helps !
huynhkhay Sat, 03/17/2007 - 03:21
If you have a Java error exception (access denied or something like that), your version of JAVA is too new for the PDM. Java 1.4 works with older versions of PDM, not 1.5 by instance.
You have two solutions :
-upgrade your PDM
-downgrade you JAVA version on IE
digitalnetwork_srl Mon, 03/19/2007 - 09:36
I cannot upgrade my PDM.
If I have a PIX version 6.3(3) software y PDM version 1.3, what is the version of JAVA and IE to use?
tks.
abinjola Mon, 03/19/2007 - 09:40
  • Cisco Employee,
you mean you have a PDM version 1.3 ? if thats the case then you are living ages back .....anyways try downgrading your Java Run Time to 1.4 and below ....give it a try
