Trouble in accessing the Cisco ISC 4.2 Application on Solaris Web Browser
Mar 16th, 2007
hi,
i had successfully installed the Cisco ISC 4.2 on my SunFire V125 Server which is running on Solaris 10 and i was also successful to login to the ISC for the first time using the Solaris Java browser.
however, after i reboot the machine i could not access the ISC anymore and the error i was getting is as follows:
"The connection was refused when attempting to contact mdesvr:8030".
in my browser i entered the ff URL:
http://mdesvr:8030/isc/
where: mdesvr is the server name
8030 is the http port no.
i would appreciate it very much if anyone can help me in resolving this issue.
thanks,
prajakta.dixit Tue, 05/01/2007 - 08:37
Check that all processes are running post reboot. ISC may not have been configured to start automatically upon reboot. Check at $ISC_BASE/wdclient status. httpd process should be running correctly.
Configure https port as follows and then try connecting using https instead of http.
Step 1 Source the environment file, as follows:
For K shell: . $ISC_HOME/bin/vpnenv.sh
For C shell: source $ISC_HOME/bin/vpnenv.csh
Step 2 Run the command: configSecurePort.sh
where:
is the home directory for ISC, for example: /opt/isc-4.2
is the secure HTTPS port you want to use, for example: 8443.
is the name of the machine that ISC is installed on, for example: machinename.cisco.com.
Hope this helps.
Cheers,
Praj
