Default-Information-Originate in RIP
Mar 17th, 2007
I am looking at a RIP question from a documentation that I have and it has the follwing :-
Router rip
Network 1.0.0.0
Network 10.0.0.0
default-information originate
distribute-list prefix DEFAULT_OUTBOUND out
Ip prefix DEFAULT_OUTBOUND permit 0.0.0.0/0
[1] My question is what is the point of the distribute-list command here ? It is allowing all networks in the prefix-list anyway ? I think that without the distribute-list command, the default-information originate command will do the job right ?
[2] Also as an alternative can we use a floating static route or just static route in place of the
default-information originate command ? It looks like it will also accomplish the same thing.
Is this true ?
Thank you,
Cheers,
-sn-
rais Sat, 03/17/2007 - 04:50
  • Silver, 250 points or more
1. That prefix list is allowing only default-route to go out in RIP updates.
2. You can use static as well, but then you have to redistribute it into RIP. With default-information originate you can make it a conditional advertisment too. For example, originate Default only when route 1.1.1.0/24 is present in the routing table.
Hope this helps.
