1721 Boot Issue
Answered Question
Mar 17th, 2007
I have a issue with 1721 router when ever it boots up all the configurations are gone and it boots up in System Configuration Mode.And after pressing no on all configurations and router>configuration memory it shows the configurations i want the router to boot up directoly
Correct Answer by ahmednaas about 10 years 4 months ago
Check the value of the Configuration register on the router (you can see the value at the end of "sh version" output). If it is not 0x2102, the change to that value:
router#config t
router(config)#config-register 0x2102
router(config)#exit
router#copy run start
router#reload
Overall Rating: 5 (2 ratings)
Correct Answer
ahmednaas Sat, 03/17/2007 - 05:25
  • Silver, 250 points or more
router#config t
router(config)#exit
router#reload
