Lien Internet 155M vers un ISP via la FO
Mar 17th, 2007
Voila ce que nous voulons:
Mettre en place un lien de 155M avec un FAI externe via la Fibre Optique.
Nous voudrons savoir le type de routeur ainsi que les modules qui lui sont n?cessaires pour pouvoir mettre en place ce lien.
Merci de bien vouloir nous r?pondre le plus t?t possible.
paolo bevilacqua Sat, 03/17/2007 - 07:37
  • Hall of Fame,
    Founding Member
Bonsoire,
La langue du le forum c'est l'anglais.
Un router pour cette utilizazion peute-etre le 7200.
Danilo Dy Sat, 03/17/2007 - 09:16
  • Blue, 1500 points or more
The current minimum router that support 155Mbps ATM is 7200 series. The module is PA-A3-OC3 or PA-A6-OC3. However, PA-A6 requires NPE-400 and above. There's also a single-mode, multi-mode, and single-mode-long.
Check this links http://www.cisco.com/en/US/products/hw/routers/ps341/index.html
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_data_sheet09186a008014a9be.html
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_installation_guide_chapter09186a00801d1bb2.html
bonne chance!
paolo bevilacqua Sat, 03/17/2007 - 09:29
  • Hall of Fame,
    Founding Member
Not knowing what a FAI is in France, we cannot say if the circuit has to be ATM or packet-based (POS). True is that for optical networking, the starting point is the 7200 and a fast NPE.
lemine1977 Sat, 03/17/2007 - 10:27
I will try to expleine in English.
We wont to creat ? new link between us and un ISP in French (FT) it is not un ATM link. so i need to know in detail the minimum of materiel required (Router and NM) to do this.
Best regards
paolo bevilacqua Sat, 03/17/2007 - 10:43
  • Hall of Fame,
    Founding Member
You will need a minimum of 7200 router with a fast NPE (NPE-400 or better), the interface card is PA-POS-OC3xxx, where xxx is SML, SMI, or MM respectively for Single Mode Long Range, Single Mode Intermediate Range, or Multi Mode. That is, it must match the type and length of the fiber span.
Hope this helps, if so please rate post!
lemine1977 Sat, 03/17/2007 - 10:48
Thenk you for help,
I will get un 7604 router but i need the technical specification for the NM interface card required!
Best regards
