Disabling the power supply failure logging on a Cisco 7500
Mar 18th, 2007
  • Green, 3000 points or more
Hi All,
I need to disable the following power supply failure logging on my Cisco 7507 router as it consumes my logging buffer.
Mar 10 00:51:19: %CI-3-PSFAIL: Power supply 2 failure.
Thanks in advance,
Mohammed Mahmoud.
Overall Rating: 4 (1 ratings)
paolo bevilacqua Sun, 03/18/2007 - 08:02
  • Hall of Fame,
    Founding Member
1st: remove/replace the failed PS
2nd: send logging to a server and apply filtering there.
mohammedmahmoud Sun, 03/18/2007 - 08:17
Hi there,
Thanks for the reply, but my own problem is that i wont be able to replace the PS these couple of days, and i urgently need to disable this logging from flooding the router local logging.
thanks in advance,
Mohammed Mahmoud.
paolo bevilacqua Sun, 03/18/2007 - 09:11
  • Hall of Fame,
    Founding Member
For certain messages (like interface flapping) you can disable logging, but for others like this one you can't.
So the 2nd solution I gave you above is the only one. Beside, you always want to have centralized logging in a serious network. What happens if a router freezes and you want to see what happened before it did?
