03-18-2007 04:59 AM - edited 03-14-2019 08:32 PM
I have a IP Telephony network (CM 4.2, Voice Gateway, IP Phones). the network is connected to internet through two stage firewalls ( First stage: PIX and second stage: MS ISA )
I want to implmenet IP Communicator over VPN client dial-into the internet & terminate the VPN on PIX firewall and to conncet to the IP Telephony network
I want to know the ports that I should opened on the ISA server from outside to inside network
Anyone can help
Mohamed
03-18-2007 08:14 AM
SCCP is port 2000 / TCP. Then if ISA does simmetric NAT, nothing else as it will open incoming RTP ports based on outgoing.
Hope this helps, if so please rate post!
03-18-2007 05:26 PM
I had forgot at the minimum the TFTP port, so here is a document that lists all the ports:
