cisco vs billion site to site vpn
Mar 18th, 2007
I am trying to setup a pix 506e and billion router site to site ipsec vpn.
currently it will not connect i have included the output from the syslog server and the pix config.
the seting on the billion are
ESP,SHA1,3DES
thanks
Alex
Overall Rating: 5 (1 ratings)
kaachary Sun, 03/18/2007 - 07:25
  • Cisco Employee,
Please post the debug outputs for :
debug cry isa
debug cry ipsec
Also, try disabling pfs on both the devivces. And, correct the crypto ACL as "deny" statements are not supported in crypto ACL. Make sure it matches on both the ends.
*Please rate if helped.
-Kanishka
Kamal Malhotra Mon, 03/19/2007 - 01:02
  • Cisco Employee,
As per the logs, it seems that there is a device between the PIX and the router that is blocking the traffic from the PIX to the router.
Please look into it.
HTH,
Please rate if helps,
Kamal
caltexsyd Sat, 11/03/2007 - 08:29
I am also having a problem setting up a Site-to-Site VPN tunnel between a Cisco PIX 525 running v7.0 and a Billion BiPAC7402 VGO Router.
See attached configs.
handley88 Sat, 11/03/2007 - 08:39
Hey, I managed to get the tunnel working but it was never stable enough and I ended up using another pix. You might have more luck with the newer pix ios cause I was using 6.3 i think
Alex
caltexsyd Sun, 11/04/2007 - 01:16
Thanks Alex.
What vpn settings did you choose? Do you think you could send me your config settings for your pix and billion.
Rod
handley88 Sun, 11/04/2007 - 05:36
Ill have a dig around on my work computer. Have you asked billion they have a good support team for cross-vendor setups
Alex
caltexsyd Mon, 11/05/2007 - 21:20
Hi Alex, that would be great if you could send it. Thanks.
Billion are yet to respond.
handley88 Tue, 11/06/2007 - 03:59
Hey, are you UK based. I think i might have the VPN tech number for the UK.
Alex
