CME configuration help
Mar 18th, 2007
Hi All,
here is my scenario, when somebody calls to CME, after three rings the call forwards to cell phone (so far is OK), if cell phone doesn't answer, then the call redirect to CME and caller be able to leave a message on CUE. do you have any suggestion how to configure this scenario? cell phone and CME both running through Cbeyond service provider.
appreciate for your suggestion
Alex
paolo bevilacqua Sun, 03/18/2007 - 07:41
  • Hall of Fame,
    Founding Member
have you tried doing this with an hunt-group ?
Do you have pots lines to try calling the cellphone?
alex goshtaei Mon, 03/19/2007 - 09:14
there is no pots dial-peer. I didn't configure hunt group. that's all I did, "call-forward noan 2261492 timeout 10" on ephone-dn which enable it to forward call to cell phone. How can I get call back to CME?
thanks
Alex
paolo bevilacqua Mon, 03/19/2007 - 11:46
  • Hall of Fame,
    Founding Member
ASAIK, the only way to try sequentially more than one number on no-answer, is an hunt-group.
