Backup RP
Mar 18th, 2007
When configuring auto-rp on two routers for the same group, which router will be the primary RP for the group? If you use the followings command on both routers, will the higher or lower IP address of the loopback be the primary, I can't seem to find the answer in univercd?
ip pim send-rp-announce loopback0 scope 31 group-list 5
rais Mon, 03/19/2007 - 07:32
Router with the higher IP addresses will be primary.
