IOS Help
Mar 18th, 2007
guys i have cisco 2620 router with 16MB flash and 64 MB RAM.........now ihave put cisco NM 2V and VIV 2fxs card......i want to simulate alanloge calls between two routers (the other one is 2811) so can some one please advise me what would be the best IOS i shd download keeping in mind my hardware config for 2620......cheers an dthanks in advance
Overall Rating: 5 (2 ratings)
Amit Singh Sun, 03/18/2007 - 22:10
I have checked sifferent images for your router and most of them seems to have the requirement for 64MB Dram and 16MB flash, which inturn matches with your router. You maximum can get is the 12.3 IOS release for your router.You can download c2600-j1s3-mz.12.3-22.bin for your router.
My suggestion for your will be to go to the feature navigator and look the IOS and the featureset supported.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH,Please rate if it does.
-amit singh
The_guroo_2 Mon, 03/19/2007 - 17:29
Mr singh
Thanks for your email tell me one thing doies this support VOIP or my scenario....cuz someone is telling me that u have to get IP PLUS ios...........i m confused
jcorrale Mon, 03/19/2007 - 17:44
That IOS code supports the following VoIP features:
AutoQoS - VoIP
Call Admission Control for H.323 VoIP Gateways
MGCP VoIP Call Admission Control
Modem Relay Support on VoIP Platforms
SIP - Session Initiation Protocol for VoIP
SIP - Session Initiation Protocol for VoIP Enhancements
T.38 Fax Relay for VoIP H.323
Voice Over IP (VoIP)
VoIP and Cisco Express Forwarding (CEF) Interoperability
VoIP and Policy Based Routing (PBR) Interoperability
VoIP Call Admission Control using RSVP
VoIP Gateway Trunk and Carrier Based Routing Enhancements
VoIP Outgoing Trunk Group Identification and Carrier ID for Gateways
VoIP Trunk Group Label Routing Enhancement
The "s" on the file name (c2600-j1s3-mz.12.3-22.bin) means PLUS, so that IOS is a PLUS IOS code.
IOS version: 12.3(22)
Feature Set: ENTERPRISE BASIC
Hope it helps!
Juan
