how do I start with 1xB channel and activate more channels if required.
Answered Question
Mar 18th, 2007
For a VoIP project, I am building a network and since the customer's voice is very important they asked me to have a backup E1 connection as well. what I am planning is having a E1-PRI card on each router that connected to the PSTN and then create a floating static route for DDR. If the main route disappears, DDR will kick in and establish the connectivity.
My question is; how do I start with 1xB channel and activate more channels if required. I don't want whole E1 to make a call via 30 channel for one VoIP call. however, if more calls comes and load on a B channel goes up to %75 then I want second one to dial. if more traffic comes then the 3rd one 4th one etc.
Please advise.Thank you very much!
Correct Answer by paolo bevilacqua about 10 years 3 months ago
Yes and supposedly will disconnect channels as load decreases.
Hope this helps, please rate post if so!
This is "dialer threshold", plenty of info about it on CCO.
Now, backup via ISDN PRI is kind of expensive, considering it shoiuld never be used, have you looked into ADSL as backup ?
Overall Rating: 5 (2 ratings)
Correct Answer
paolo bevilacqua Mon, 03/19/2007 - 05:26
  • Hall of Fame,
    Founding Member
tonywen Mon, 03/19/2007 - 20:19
Hi Paolo
Thank you very much.
By configuring only one dial peer and point it to the pilot number then it will automatically increment the number of channels as the load increases.
Thank you again for your help.Appreciated!
Tony
Correct Answer
paolo bevilacqua Tue, 03/20/2007 - 03:39
  • Hall of Fame,
    Founding Member
