pix 515E failover
Mar 19th, 2007
I have Pix 515E- Failover . when I power on just boot a little boot then freeze.
I try to go rommon mode by press key break and ESC but no work,so it is hardware problem ??.
IOS::6.3
biplob
hoogen_82 Mon, 03/19/2007 - 01:53
  • Silver, 250 points or more
Could you post the capture that you have done.
Hoogen
abinjola Mon, 03/19/2007 - 09:44
  • Cisco Employee,
neither its booting nor getting through the ROM mode..i would suggest you to stop wasting further time on this device and get this replaced...possibly bad flash
iqbalkhan Wed, 03/28/2007 - 04:20
hi
message : PCI device table
BUs Dev Func Table
when I enter ESC key
then message come in
testing mod menu
1 test floating point
ccontinue
hoogen_82 Wed, 03/28/2007 - 04:22
Hardware problem, replace your PIX.
Hoogen
Do rate if this helps
